HELP! intermittent engine problem
Old Nov 26, 2023 | 03:24 PM
N.W.Ford's Avatar
N.W.Ford
Hello, Ill give some backstory on the truck first. its a '74 f250 with a 1968 lincoln 460 engine swapped in it. The problem is it will be idling fine at about 800, or driving fine and then at a stop or idling it will suddenly fall to 400 rpm and barely running, and in that state the engine turns over faster than otherwise. so i have a feeling its timing related. what ive done is swapped the old unilite distributor with an oem one for that engine, and set timing to where it feels best with manifold vacuum engaged at idle. and I did check timing chain slop it looked like no more than a half inch or so turning the engine by hand.
Thats all for now i will update this thread as i mess with it, and i appreciate any help with this issue.
Thanks, Nigel
Old Nov 26, 2023 | 06:20 PM
LandAndStone's Avatar
LandAndStone
Desk Jockey
At what RPM was timing set? What is timing set at? What is curb idle? I usually set timing at 650 RPM with vac adv plugged. Curb idle around the same.
Old Nov 26, 2023 | 07:47 PM
440 sixpack's Avatar
440 sixpack
Are you hooked to ported or manifold vacuum? this is a typical symptom of manifold vacuum on a set up curved for ported vacuum.
rock2610d
15
Sep 19, 2023 09:01 AM
Scouder
32
May 3, 2006 08:25 AM
goldfever
1983 - 2012 Ranger & B-Series
Mar 31, 2005 05:02 PM
warrenballard
Dec 26, 2003 11:07 AM
1972 Ford Thunderbird 429 V8
Oct 2, 2002 12:41 AM
