Fuel line
Old Nov 19, 2023 | 11:42 AM
hjartland's Avatar
hjartland
Fuel line
My fuel line from the frame to the fuel rail got cut and needs to be replaced.
I can not seem to find a replacement any where.
Ideas?
1993 F-150 XLT 4×4 351W 5.8L E4OD
Old Nov 20, 2023 | 04:18 AM
manicmechanic007's Avatar
manicmechanic007
The junkyard is your best option
Those two lines will be hooked together at a bellhousing bolt
They can also be repaired but with difficulty
I would look for a good set at the wrecking yard
Old Nov 20, 2023 | 07:42 AM
hjartland's Avatar
hjartland
The line is only leaking where it scraped against something. How would I try to repair it?
The leak drips enough to be a problem, but not spraying out.
Old Nov 20, 2023 | 09:19 AM
R&RFord's Avatar
R&RFord
Ford made repair kits. Be aware of the fitting sizes. An example:
https://www.ebay.com/itm/353886935850
Old Nov 20, 2023 | 09:34 AM
jas88's Avatar
jas88
WRT the Ford repair kit on eBay, it's interesting that the lister says its for a 91 F250, but it has a 94 part number.
Old Nov 20, 2023 | 01:04 PM
My4Fordtrucks's Avatar
My4Fordtrucks
1991 would have the same fuel system. In 1994ish they determined that there was a need for a repair kit would make sense to me.
Mickw
Mar 12, 2023 08:50 AM
chesster51
Jul 28, 2022 07:01 PM
nathanr561
Aug 3, 2019 05:18 PM
460 FORD MAN
Aug 14, 2014 09:38 PM
MP&C
Jul 12, 2010 03:48 AM
