Fuel rail line
Old Mar 10, 2023 | 06:27 PM
Mickw's Avatar
Mickw
Fuel rail line
95 f150 with a 5.8. Found a small leak in the rail lines, replacing it with 5/16 rubber fuel line. Does this set up look like it will work?
Old Mar 10, 2023 | 06:32 PM
spurredon's Avatar
spurredon
Is it pressure rated tubing?
Old Mar 10, 2023 | 06:45 PM
Mickw's Avatar
Mickw
Its rated for 50 PSI
Old Mar 11, 2023 | 01:54 AM
TexasGuy001's Avatar
TexasGuy001
As long as the new fuel hose is actually for EFI and has the interior liner it should be fine, but regular hose clamps are not. There are different style ones designed for higher pressure and I would use them.
Old Mar 11, 2023 | 03:11 AM
Mickw's Avatar
Mickw
sounds good, i gotta feeling my hose is probably too weak then. I picked up some fuel line hose at napa, its rated at 50 PSI. Guess i wasnt accounting for a case of a failed FPR, that would be a bad. and i figured the clamps would do a good enough job. But Ill keep the same routing/ style of the hoses with some stronger line and better clamps . I Appreciate the input
Old Mar 12, 2023 | 08:50 AM
manicmechanic007's Avatar
manicmechanic007
They also make high pressure fuel line (factory on some Chryslers)
That has a teflon inner liner (lasts about forever)
What you have done should last several years
rmo5095
Nov 29, 2023 07:08 AM
cgph4693
6.7L Power Stroke Diesel
Oct 28, 2020 09:22 AM
nathanr561
Aug 3, 2019 05:18 PM
Tugly
Aug 23, 2014 09:03 PM
SideWinder4.9l
Feb 9, 2012 06:34 AM
