Ecm compatability
Old Apr 6, 2026 | 02:01 PM
  #31
andreleplattenier's Avatar
andreleplattenier
8th Gear
Originally Posted by asavage
That's what I thought, over here. However... use.
Thank you savage! You and WWhite have been tremendously helpful. I think my next steps are to put the truck back together to start testing pins to ECM as stated and find someone wiling to tackle the board repair. I'll update the threads as to what my solution is when/if I find one.
Old Jun 11, 2026 | 06:12 PM
  #32
Ford4meOnly's Avatar
Ford4meOnly
4wd Low
I had the same resistor burn up on my 1996 F250 7.5L E40D. The EEC was F6TF-12A650-AHA. I checked connectivity and it goes to pin 4 on the connector. This controls the ignition control module. I am replacing both the EEC and the ICM.
Old Jun 12, 2026 | 08:01 AM
  #33
1Butcher's Avatar
1Butcher
Smart move. Everything fails, but a resistor failing that that would make me believe something caused that.
Shadetreejunkie
16
Nov 5, 2023 07:11 AM
rjlavs
Sep 7, 2023 09:01 AM
cometgt1974
Jan 31, 2011 03:05 PM
oldmansimek
Dec 18, 2009 01:08 PM
RRranch
May 21, 2009 02:15 PM
