Newbie needs help w/ 96 F-150
Hey everybody, new here but i'm a long time ford truck owner. I'm working on a friends truck and it has me pulling my hair out, was wondering if you guys could help. Its a 92, F-150 w/ a 4.9l . Basically, it runs like crap and sometimes won't run at all, I scanned the codes and got the dreaded "running in failure mode" code and basically most of the engine sensors are throwing a "low voltage code". I can't find a pin-out for this particular model on the internet but I did go ahead and check to make sure I was getting power at the computer harness, and it is, in several locations. Basically, can someone point me in the right direction for a pinout for this truck and how I should test each pin once I get it?? I'm just trying to determine if it needs a new computer, I don't want to buy parts that it doesn't need!! I really appreciate any help as this truck has me at my wits end!!!
Last edited by cometgt1974; 01-31-2011 at 11:22 AM. Reason: it's a 92 model NOT A 96
Bill posted a pinout for a 4.9L truck with OBD-II a few months ago. Take a look here: https://www.ford-trucks.com/forums/9...n-diagram.html
Ok, I got the eec IV pinout and did some probing and it appears that the computer is getting good voltage and the grounds have continuity. I am now leaning to a spark or fuel supply issue.... the pressure is reading about 50 psi when I turn the key on. I am getting good strong spark at the coil. I'm gonna do some testin a the TFI using some info that I got here. Any help or suggestions is appreciated.
