Sponsored by: Real Truck
2008 Powerstroke no-start
Old Jan 28, 2024 | 07:25 PM
projectSHO89's Avatar
projectSHO89
All of this was complicated by the fact that circuit diagram we had, post above, was WRONG.
Well, the diagram you posted was for a 2009. You indicated you have a 2008.
The 2008 starting circuit for the diesel had two versions, an early and a late production, of the starter circuits according to the EVTM. Sounds like you may have had the early production model and didn't realized it until recently. The late-2008 diagram is similar to the 2009 diagram posted but there are some differences (which I haven't dug into).
Old Jan 28, 2024 | 10:05 PM
AllenV's Avatar
AllenV
That's right. The diagram we found was for 2009. It's more different than I had thought it might be.
The truck is late production. Early models don't have OTIS. I'll put up the right diagram tomorrow.
Old Jan 29, 2024 | 07:56 AM
projectSHO89
Here it is.
And, for anyone who might need it in the future, here's the early production diesel starting diagram from the EVTM.
Old Jan 29, 2024 | 09:30 AM
AllenV's Avatar
AllenV
Here is the complete diagram for 2008 late production F250
This includes important items missing from the ones posted above. This has CDIM located between the battery and the ignition switch. For automatic transmissions it includes the TCM connection to the PCM.
If you are debugging a starting problem using these circuits it is important to know that the PCM controls the cranking process by shifting the yellow wire from +12V to GND as needed.
Old Jan 29, 2024 | 09:53 AM
projectSHO89
Is your truck equipped with CDIM?
Old Jan 29, 2024 | 09:57 AM
AllenV's Avatar
AllenV
Yes it is. That has been a source of some debugging challenge as it sits right between the battery and the ignition switch.
The truck is an '08 King Ranch Powerstroke. I thought all late production trucks would have CDIM. Is this not the case?
Old Jan 29, 2024 | 10:15 AM
projectSHO89
IIRC, it was required on late 2008 models built to California or green state emissions standards. If your underhood emissions compliance tag says "California", then that's what it has.
Did you find that the the CDIM was working okay and that the problem was downstream at or in the ignition switch?
Old Jan 29, 2024 | 11:08 AM
AllenV's Avatar
AllenV
@projectSHO89
The truck came from Texas. I think it was first registered there. But I bought used so...
I am curious to know why emissions states care about CDIM. This is purely an anti-theft feature, part of PATS (Passive Anti-theft System). here is a video I just found on PATS in the 2008 F250. He does not include the CDIM in his bench set up. The video is focused on the flashing "lock" dash light whereas the CDIM is the action end of things that actually switch off power to the ignition switch to disable the truck.
Finally, what is IIRC?
Old Jan 29, 2024 | 11:13 AM
AllenV's Avatar
AllenV
I forgot part of your question, yes, it seems the CDIM is functioning as intended.
The ignition switch contacts in START position appear to be faulty. We can see with a DVM that the concats close only for part of the key rotation then often (but not always!) go back open.
Old Jan 29, 2024 | 11:34 AM
AllenV's Avatar
AllenV
@projectSHO89
Interesting, I just found an old post. of yours
https://www.ford-trucks.com/forums/1...dule-cdim.html
where you bring up the CA emissions "Diesel Engine Idle Shutdown" using the CDIM to turn the motor off if left idling too long.
The "out" for our F250 is that the GVRW is less than 14000 lbs, so F250 of that year in CA should be exempt from this.
Anyway... perhaps Ford put the CDIM to dual use? It would be a simple matter to take a PATS device and reprogram it to shut the truck down if left idling.
Now you have me curious. I'll dig out the component location map and try to lay eyes on a CDIM. That'll take a while as the truck lives with my son now. About an hour south of here.
Old Jan 29, 2024 | 11:55 AM
AllenV's Avatar
AllenV
I am learning quite a bit about this now.
Here is PATS from the Ford service software
Notice it makes no mention of the CDIM
Old Jan 29, 2024 | 11:57 AM
AllenV's Avatar
AllenV
And here is "engine shut down timer"
Old Jan 29, 2024 | 11:58 AM
  #28
AllenV's Avatar
AllenV
Now I am thinking that when I go looking, I will not find a CDIM.
The point is moot, anyway. But educational.
Old Jan 29, 2024 | 01:35 PM
  #29
ifrythings's Avatar
ifrythings
One thing I found one time was if the transmission shift cable was adjusted wrong, the TCM wouldn’t send out the “ok to start” message to the pcm, cluster showed the right gear and no codes, the cable was adjusted basically past park on the transmission (not towards reverse) and required you to pull the shifter just below the park detent for it to start, I believe neutral worked correctly to start.
I found it when using forscan and monitoring all the start condition pids ( don’t t remember the exact ones off hand). If I was in situation I would hook up forscan and monitor the ignition switch in the SJB/BCM, start request in pcm, pats ok to start just to name a few.
Old Feb 3, 2024 | 05:35 PM
  #30
AllenV's Avatar
AllenV
SUCCESSFUL RESOLUTION
We put in that new ignition switch. All is now good. Truck is back on the road.
Thank You for your help and counsel.
Aenima19
Jan 30, 2024 09:03 AM
cjben
Mar 16, 2016 03:54 PM
Stonesetter1
May 29, 2015 02:31 PM
bigfix
Jan 1, 2012 05:39 PM
17fordguy
13
Oct 10, 2007 04:16 PM
