Replace, right?
Old Nov 18, 2023 | 12:34 PM
oldbird1965's Avatar
oldbird1965
Replace, right?
I haven't checked the other side yet but was wondering about a certain 'brand' to buy. I'll be replacing both.
Old Nov 18, 2023 | 12:57 PM
97-psd's Avatar
97-psd
That thing has been a touch warm Glenn! I am currently running a set of Wagner’s, I think they are “extreme duty” or something with a silly label. I think powerstop makes drilled and slotted rotors for a little more performance/cooling
Old Nov 18, 2023 | 02:53 PM
oldbird1965
Yea, this 5er is 18K heavy! Where did you get the Wagner's?
Old Nov 18, 2023 | 03:18 PM
97-psd's Avatar
97-psd
IIRC it was rockauto
Old Nov 18, 2023 | 04:38 PM
farmert's Avatar
farmert
I have had good luck with the NAPA premium brakes/rotors.
Old Nov 18, 2023 | 07:08 PM
oldbird1965
I've also have had good luck with napa brake pads. Rockauto has motorcraft hubs, now to figure out the bearings and races.
Old Nov 18, 2023 | 08:22 PM
fordman67's Avatar
fordman67
Wow, I would say inspection was a great to find that. Man. Thats scary
Old Nov 19, 2023 | 10:44 AM
oldbird1965
New motorcraft hubs are on the way. Any suggestions on a bearing, race and oil seal kit for the new hubs? Thanks
Old Nov 19, 2023 | 10:48 AM
Hit Man X's Avatar
Hit Man X
I like Timken for domestic stuff.
Old Nov 26, 2023 | 08:35 AM
tshrager's Avatar
tshrager
Glenn, I don't get on here much and I assume you already have these replaced. However, I have had very good luck with powerstop stuff. I pretty much order everything on the internet these days, so I wouldn't be able to tell you where to get them locally. As far as bearings, agree with above. Timken has treated me well.
Old Nov 27, 2023 | 12:16 PM
oldbird1965
I just got my motorcraft hubs, they have races in them already. I've read pro's and con's of using installed races. The bearings come with races that are supposedly 'matched' to the bearing. Should I remove the installed races and replace them or use the already installed races??
Good to know about powerstop, thanks Todd.
Old Nov 27, 2023 | 02:36 PM
farmert's Avatar
farmert
I'd use the installed races, Glen.
Old Nov 27, 2023 | 02:59 PM
mpost3r's Avatar
mpost3r
I hate being an armchair warrior but I guess that's what forums are for--I'd inspect your wheel bearings, too. These trucks don't have good brake cooling at all and often times it can cook the grease in the bearings. Two grease seals and some patience is all it takes, especially if you're in there to replace the rotors! re pack those bearings!
Old Nov 28, 2023 | 08:06 AM
oldbird1965
Thanks Tom, I think I will just use the installed races.
I ordered new bearings, suppose to be here today.
Just Chilling
6.7L Power Stroke Diesel
22
May 31, 2022 08:39 AM
senix
All Things Towing
13
Jan 17, 2022 07:19 AM
Gringostr
Dec 16, 2020 03:17 PM
892504x4
Nov 14, 2019 09:46 PM
davewave649
Oct 7, 2012 02:40 PM
