How is the bed deck attached to the side walls? Spot welded? This photo does not really show it, but I can see small spots of daylight through this joint in the front left corner. Almost looks like it was caulked. My bed is has Line-X.
Bed is purposely put together with gaps for drainage.
And, yes, spot welded.
I didn't think there was any welding on the aluminum body. Parts are bonded together with adhesive. I could be wrong but recall Ford reported they got rid of all welding (a big workplace improvement) when they converted the F150 factory to build the aluminum truck bodies.
