2001 7.3 excursion coolant
Old Nov 14, 2023 | 06:09 PM
7.3Xcursion's Avatar
7.3Xcursion
I've been trying to find what coolant I need to use in my truck. I'm not sure when it was last changed, or what it was changed with. I've read that there are green coolants that needs SCA's, or Extended Life Coolant that can be used in only certain trucks. This information is all pretty old. What is the best coolant I can get for my engine nowadays? I'm not sure of the date code on the engine.
Old Nov 14, 2023 | 06:37 PM
INFRNL's Avatar
INFRNL
I have an 03 but an older forged rod block that's been rebuilt. I run extended life coolant. I used to use chevron but now just get it from my kenworth dealer.
I'm sure others will be in to tell you what they use. i also think there's a recent thread about this somewhere around here
Old Nov 14, 2023 | 10:46 PM
John in OkieLand's Avatar
John in OkieLand
I have an '02 Excursion, and got so confused with what "everyone was saying",
that I just went with NAPA gold until I hear more "evidence"
I first thought I was to get ELC, but the rumor mill spoiled that, to my consternation, WTH is ELC bad for the older blocks?
Old Nov 14, 2023 | 11:36 PM
Socket's Avatar
Socket
L99-03 7.3s can use ELC. It was the E99 7.3s that had an issue with it. This is a very detailed break down of which engines can and can’t use it and the best way to flush them as well.
https://www.ford-trucks.com/forums/9...ml#post8935201
Old Nov 15, 2023 | 07:33 AM
CousinCarl's Avatar
CousinCarl
Doesn't play nicely with injector cup material Ford used prior to switching. Thread linked above has some great info to feel confident on making an informed decision.
Old Nov 15, 2023 | 01:30 PM
helifixer's Avatar
helifixer
My 97 has had CAT ELC coolant in it for about 10 years, now at 320,000 miles, no injector cup problems yet.
not everyone is so lucky?
Old Nov 15, 2023 | 02:54 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
CAT ELC here too for 400,000 miles, no issues. Had gold from the factory for the first 100,000 and slight cavitation arose on front cover. The CAT ELC stopped it in it’s tracks. Looks exactly the same at 500,000 miles, as it did when I converted.
Old Nov 16, 2023 | 01:32 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Put me in the gold coolant fan club. It's cheaper than ELC, and totes better than green on SLCs.
Coolant is a consumable product like brake pads, never intended to last forever. Way more likely to be dumped for a water pump change or some other leak way before it ages out.
Old Nov 16, 2023 | 03:01 PM
INFRNL's Avatar
INFRNL
Cheaper? I get my ELC for $8-10/ gal...I just like the red, fit's my color scheme. I think it's just a matter of time before green is basically obsolete and yellow/ gold replaces it.
GEugeneS
26
Sep 8, 2023 07:32 AM
96SD
Nov 30, 2022 01:39 PM
D.S.
Nov 10, 2004 08:17 PM
sdmotor
Oct 17, 2002 09:58 AM
