Fluid Changed Now Limp Mode
Old Nov 22, 2003 | 12:32 AM
benny111's Avatar
benny111
CAN SOMEONE HELP PLEASE. I CHANGED THE TRANS FLUID AND FILTER, AT THE SAME TIME I DRAINED THER CONVERTER. AFTER I REFILLED THE PAN AND CONVERTER EVERYTHING SEEMED FINE SHIFTING WISE BUT THEN I NOTICED I WAS IN LIMP MODE WHEN I NEVER SHIFTED PAST SECOND GEAR. I CHECKED THE LEVEL, IT'S FINE TRIED TO DISCONNECT THE BATTERIES FOR ABOUT AN HOUR TO LET THE COMPUTER RESET AND THAT WAS NO GOOD. ANY HELP AT THIS POINT WOULD BE NICE HEAR RIGHT ABOUT NOW. THANKS
Old Nov 22, 2003 | 08:10 AM
jim henderson's Avatar
jim henderson
Hmmm, check the dipstick for excessive foaming. Some bubbles are normal but if the stick has a lot, especially if they go way up the stick then I would suspect you didn't properly install the filter and are sucking air into the system.
All this assumes your tranny was working fine before.
You might also have accidentally disconnected one of the electronic devices inside when you opened it up.
While you had the pan you should check any visible bolt for looseness and snug it back up, be gentle, aluminum strips easy.
You might recheck fluid level again and be sure to follow the manual procedure exactly. A grossly incorrect fluid level might cause things to go wrong. The TC takes a lot of fluid and it may take awhile to get all the air out of the system.
If it was my guess, I would say filter is sucking air.
Good Luck,
Jim Henderson
Old Nov 22, 2003 | 09:27 AM
benny111's Avatar
benny111
Jim
I should of mentioned that the truck is a 2000 f350 with 7.3PSD, it had no problems but a refreshing was in order. There is no foaming, that I did check for on the stick, the fill level I intentionally went just at the high mark on the stick. It's not showing me any leaks at the pan before or after the service. I visually checked externally at the trans for electrical connections and all seems fine. I have no idea what else to check for, and thanks for some ideas Jim I appreciate it.
Could Be Better,
FRANK
Old Nov 22, 2003 | 10:45 AM
benny111's Avatar
benny111
I just wanted to add that there are no lights on the dash on, and the O/D light is not flashing on either
tbon63
Jun 20, 2021 04:14 PM
Thor'sHammer
33
Feb 10, 2015 01:02 AM
akamacgyver
Oct 4, 2014 12:55 PM
TheBrettster
Dec 30, 2010 08:50 PM
rustee90-150
1978 - 1996 Big Bronco
Sep 17, 2008 12:24 PM
