orig. 7.3 w/factory turbo
IP is about 10 years old but only 20k miles
injectors were not changed out with the IP, could be original,
up until about 3 years ago when I would step on the pedal hard I'd get good black smoke out the exhaust,
I've started to notice a change in the smoke color until now it's a gray or hardly visible cloud when I accelerate hard under load
The truck seems to run good and the only odd issue is that sometimes when going uphill at a constant speed it will seem to loose power (not rpm's) and chugg (not exactly sure how to describe the loss of power but hear a difference in the exhaust)
You can confirm that all of the injectors are popping correctly by loosening the fuel line nut on top of the injectors one at a time with the truck idling. The idle should change when you loosen the fuel line nut. If the idle doesn't change you know the injector is suspect.
I just mentioned that because you said the injectors might be OE. I thought our IDIs would spit white smoke due to air intrusion. Gray; or more likely blue, smoke can indicate worn valve guide seals on a gas engine. Especially if it's only evident when cold. Our IDIs would probably eat extra oil from worn valve guide seals as a snack.
fuel filter was checked, was clean and refilled ATF about 2k miles ago, about 14 months,
problem has been going on before then,
about 3 years ago I replaced the shower head pickups and ended up replacing both tanks because the silt was so bad in the bottom of the tanks after 10 years https://www.ford-trucks.com/forums/1...w-problem.html
I honestly don't know if the gray smoke was happening before that, I know it would chugg occasionally before that,
It may be a week or two but I'll try to get a video,
the sound is all from the exhaust, it just gets a hollow, definitive, repetitive chugging,
If I keep the pedal the same I BELIEVE the rpms hold but I just start to loose power and slow down, If I step on the pedal it throws it into overdrive, the rpms increase, the chugging stops and I pick up power again,
thinking more about it, fuel starvation does seems like a possibility,
