7.3 white smoke
Old Sep 30, 2023 | 07:50 PM
Tbugs58's Avatar
Tbugs58
Trailering
7.3 white smoke
Hey, so I just did my injector o rings and it started up like it usually does. I’ve put about 10 miles on her but she’s been pushing excessive white smoke out. I did a little test by pulling the uvch connectors one at a time (the side that controls 2, not the individual ones). When I pulled the front passenger one the white smoke completely disappeared. Is this a bad injector? Or did I bust a ring or roll it? I was thinking that if it was just a ring then unplugging it wouldn’t change anything.
Old Sep 30, 2023 | 07:57 PM
helifixer's Avatar
helifixer
Go drive it 50 miles or more, and push it. Then post back, you can get a lot of oil in the exhaust system when doing injectors and need to burn it out
Old Sep 30, 2023 | 09:59 PM
Tbugs58's Avatar
Tbugs58
Trailering
that’s what I thought but I just tried driving it with the front passenger uvch unplugged and it ran normalish and zero white smoke. So I know there is something wrong with one or both of those two injectors. When I plugged it back in it started spewing white again. Iv
Old Sep 30, 2023 | 11:07 PM
z31freakify's Avatar
z31freakify
Were they/it the injector/s that were removed first? If so like Helifixer just posted got to drive it more to burn all the oil and fuel out.
Also a missing coper washer on an injector can cause the smoke
Old Sep 30, 2023 | 11:12 PM
Tbugs58's Avatar
Tbugs58
Trailering
I’ll check the washer, they were not the first, I vacuumed them out immediately after pulling as well. I’ve done a few injectors jobs and have never had this much smoke so I’ll check for the copper washer.
Rich21
Apr 2, 2017 12:00 AM
beersy50
Nov 15, 2009 07:32 PM
sassydog
General Diesel Discussion
Nov 22, 2007 10:03 AM
stockernavstar
Jan 13, 2006 12:40 AM
