Sponsored by: Real Truck
Output shaft speed sensor (OSS) problems
Old Nov 6, 2023 | 05:32 PM
RemingtonCG's Avatar
RemingtonCG
I have an 03 6.0 that I just replaced the trans in, new trans is out of an 03 as well. Long story short I got it all back together and it’s giving all the usual signs of the oss going out. It’s throwing the p0720 code. I replaced it and nothing changed. So I checked the resistance for all the wires that go to the sensor, when I checked them all individually, From sensor connector to the pcm connector (c1381b). I got zeros all across the board, but when I checked between the 12v (reference voltage) wire to the ground (signal return) wire I got 1970 on my meter. I’m not experienced with a multi meter or electrical problems. But dose that mean I have a short between those two wires. I did check between the 12v and ground wires whilst it was running and got 12v every. Any advice is appreciated.
Old Nov 6, 2023 | 05:38 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Was the harness disconnected on both ends when you checked the resistance?
Old Nov 6, 2023 | 05:48 PM
RemingtonCG
Oss
Yes, I was just sitting here wondering if that would make a difference
Old Nov 6, 2023 | 06:04 PM
RemingtonCG
Oss
I checked from the pcm connector to the sensor connector when checking each wire individually, but when I checked the 12v and ground wire I checked them both from the sensor connector. The pcm end was unplugged while I was taking that measurement.
Old Nov 6, 2023 | 07:48 PM
Mark Kovalsky
Was it also disconnected at the sensor end?
Old Nov 6, 2023 | 09:24 PM
RemingtonCG
Solution
Well I did some more poking around and checked the ohms on the OSS and I had a bad out of the box unit. Swapped it out and that problem if solved. New problem is the transmission is throwing an incorrect gear, ratio code. Which is causing it to go into fourth gear and cause my overdrive light to flash again. Is this something that if I just keep driving it gently it will relearn or is it going to be a deeper problem try than that?
Old Nov 7, 2023 | 07:16 AM
Mark Kovalsky
It won't relearn. Try clearing the code and see if it returns.
Old Nov 7, 2023 | 07:26 AM
RemingtonCG
New problems
well I cleared the codes and have been driving it all morning. I hasn’t gotten stuck in 4th or thrown a code, but it has a real bad 3-5 flair and an even harder 5-6 shift. So I’m not sure if my trans is a dud or if it’s electronic. Going to drive it easy the rest of the day and check the codes again.
zbussey
Aug 2, 2024 10:50 PM
chrisjrosenbohm
Apr 25, 2023 09:31 AM
Leon2000
Electrical Systems/Wiring
May 5, 2021 05:39 AM
Alcaeus
Aug 6, 2016 09:48 AM
tomherrick
Dec 2, 2007 04:05 PM
