LED lights are in.
Old Nov 3, 2023 | 07:03 PM
GM in a Ford's Avatar
GM in a Ford
LED lights are in.
I have put LED lights on my truck. Went with amber fogs and glad I did. Only test drove them tonight and think they will be a vast improvement over factory lights.
Only replaced two of the four headlights as I think it will bother people if I did all four. Would love to see the output of 4 LEDs though.
Check out the short video below.
Popular Reply
Nov 3, 2023, 10:41 PM
GAZZILLA's Avatar
GAZZILLA
Roads here are very dark.
IMO, LED bulbs in halogen housing are blinding, hazardous and inconsiderate to others.
Old Nov 3, 2023 | 08:45 PM
SDER1's Avatar
SDER1
I made the switch to all LED bulbs in my 2017 F350, making an marketable improvement at night between halogen and LED clarity of the road. What brand of LED bulbs did you use? I have a mix of Auxito, Alla, and Beamtech (front & fogs). FORSCAN setting for Bambi is great for those dark nights and roads, to include preventing hyper-flash for turn signal bulbs.
Old Nov 3, 2023 | 10:41 PM
GAZZILLA's Avatar
GAZZILLA
Old Nov 4, 2023 | 02:40 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Cool, now you get to blind every oncoming driver
Old Nov 4, 2023 | 05:29 AM
Poncho450's Avatar
Poncho450
I won't get into the LED/halogen housing argument. No one wins the endless circle.
However, I went with the yellow fogs a few years ago. Big improvement for me. I also have them set to come on with DRL. Nice contrast between the yellow and the white of the headlights and switchback turn signals. Much easier to be seen.
Old Nov 4, 2023 | 06:19 AM
GM in a Ford
I knew there would be naysayers. I was one once. But until you try it for yourself and see the nice cutoff of the light you will not believe it does work. I think the first LED replacements had that problem but not anymore.
Old Nov 4, 2023 | 06:42 AM
GM in a Ford
I used Auxito for the foglights and Torchbeam for the headlights.
Old Nov 4, 2023 | 08:20 AM
jade97's Avatar
jade97
One just needs to properly realign the headlights after installing LEDs. Probably 99% of those people blinding you with aftermarket LEDs, never realigned their headlights.
Old Nov 4, 2023 | 10:50 AM
Poncho450's Avatar
Poncho450
I seldom get flashed. And when I do I think it's mainly because people see all 4 headlights on and assume that the high beams are on.
I got some pointers here:
Old Nov 4, 2023 | 04:04 PM
NedFletcher's Avatar
NedFletcher
I have the headlight LEDs from F150leds and I've never been flashed for it, but i spent some time aligning them and tested it with a cop in his cruiser to see if they caused him any problems. Id agree that a majority of the problem is probably people who didn't allign them.
I was hoping to just stick with halogens on these but they were dim as could be and after having a bulb burn out and having to change it on the side of the highway I appreciate the longevity of LEDs more than I ever have before
Old Nov 4, 2023 | 04:11 PM
GAZZILLA's Avatar
GAZZILLA
If you think four halogen headlights on a tall pickup are dim, maybe you shouldn’t be driving at night.
Old Nov 4, 2023 | 07:04 PM
wheelerfreak's Avatar
wheelerfreak
I disagree in the case of my F350. I don't have and don't plan to swap out to LED bulbs, but the stock headlights suck. The light is yellowish and about on par, IMO, with the single halogen lights in my 30 year old Dodge truck or my '73 Bronco, which is not good either. If all you do is lighted road driving, then they are fine. On unlit roads in BFE, I prefer a better light to see down the road and avoid critters. The factory LED lights in my Nissan and my Wife's Honda are so much better and don't blind other drivers.
I think many issues with replacement LED bulbs are buying cheap or improper lights bulbs and not aiming them correctly.
Old Nov 4, 2023 | 07:22 PM
honda250xtitan's Avatar
honda250xtitan
dude the video preview alone shows the massive glare lmao. if you need better lights, add auxiliary lights on a separate switch.
Old Nov 4, 2023 | 07:39 PM
Rwhjr's Avatar
Rwhjr
I’ve had both and agree with most that the halogens on super duty trucks suck
the led’s are much better. Guess that means I shouldn’t drive at night lol.
But ive never done a led swap into factory halogen housings either so im not sure if you can find the right led to reduce glare or not
Old Nov 5, 2023 | 01:05 AM
honda250xtitan
do it right. embrace the suck and do an actual retrofit with projectors. hate your life while youre cooking the headlight in the oven and then wrestling with hot plastic trying to pull the lens off the assembly. Not like i have any ptsd from this process a time or 3.
