Kickdown bracket
Old Apr 16, 2024 | 09:18 AM
8Line's Avatar
8Line
Originally Posted by TA455HO
... For a custom combination many people use the Lokar kits but I'd bet you could find a kickdown combo for a 429 and C6 since they would have originally had a setup for that. People often have noted that a change to carb from 2 bbl to 4 bbl have required changes to the kickdown. Carb spacers and other changes can also throw off the geometry.
good to know. i'll keep an eye out for some of this stuff. not needed now as I can alwasy just drop to 2nd as needed. but would definately be a "nice-to-have" sorta thing. THanks!
Old Apr 16, 2024 | 10:02 AM
Crop Duster's Avatar
Crop Duster
You have no choice but to buy a Lokar kit. You have a tunnel ram with two 4 bbl. carbs. There are no factory parts for that. The transmission will not work as designed without the kickdown working. Without the kickdown connected your trans is shifting only on torque demand and not throttle position.
abe
Sep 13, 2023 06:07 PM
smallello
Dec 27, 2021 11:04 PM
TCLyford
Dec 1, 2013 10:15 AM
78_f800crewcab4x4
Large Truck
Apr 6, 2011 03:41 AM
Brian's 48
Oct 19, 2010 07:24 PM
