Motor Mount replacement
Old Nov 2, 2023 | 09:01 PM
RigCity's Avatar
RigCity
Any tips for the motor mounts? Did the transmission mount tonight as the transfer case was resting on the skid plate. Truck has a ton less vibration and the transmission is just under a 1/2 inch taller. Might as well do the engine mounts. Thanks for the help
Old Nov 2, 2023 | 09:23 PM
udsuth78's Avatar
udsuth78
Are you wanting to do this with the engine installed? That could prove tricky. The bolts at the crossmember aren't too bad, easier still if it's 2wd but accessing the bolts on the block might be a bear.
Old Nov 3, 2023 | 04:50 PM
INFRNL's Avatar
INFRNL
It's a bit of a pain to get the engine back in on it's own. Not sure how bad it would be to try and replace the mounts individually. a lot of time and patience i suppose.
If you don't see any issues with them, I'm not too sure I would worry about them. I just had my engine rebuilt a few years ago and reused the originals. I have close to 240k on my truck. No issues with motor mounts or vibration
octaneforce
Nov 18, 2009 03:54 AM
prerunner
4 Cylinder Engines
Feb 11, 2007 10:50 AM
RustyTrustyF150
Oct 20, 2005 04:59 PM
nastruk95
Mar 9, 2005 09:30 AM
Fluorspar1
May 4, 2003 10:27 PM
