So I’ve changed changed
spark plugs
wires
distributor cap
map manifold sensor.
truck now smells like it’s running rich with a idle that chokes every 8 to 10 seconds. Doesn’t turn off and still runs but I don’t like the idle.
any ideas?
Assuming the truck ran okay with the old one based on this statement: "truck now smells like it’s running rich with a idle that chokes every 8 to 10 seconds."
It would also help to know what year/model/engine/transmission truck you are working on.
If that doesn't fix it have you changed the O2 sensor? Assuming no engine light? Check for codes just in case? Just because the engine light isn't on doesn't mean codes aren't present.
