idle
Old Feb 23, 2010 | 05:07 PM
bigland's Avatar
bigland
idle
hi guys
just rebuilt motocraft 2150. removed vacuume choke and installed manual choke. Also never reinstalled High idle adjustment as there were pieces missing. Current temperature is slighty below zero and I cant get the truck to idle even after temp hand reaches normal.
Any suggestions
Old Feb 23, 2010 | 06:31 PM
alans77crew's Avatar
alans77crew
Do you have a rather large vacume leak! that's where I'd start.
Old Feb 23, 2010 | 06:41 PM
bigland's Avatar
bigland
Nothing thats apparent If I hold the pedal slighty down it runs smooth. Do i need the fast idle still hooked up with a manual choke?
Old Feb 23, 2010 | 06:59 PM
4x4 Bart's Avatar
4x4 Bart
You need to look at the idle screw and make sure the fast idle cam is not holding the throttle open. When it's warmed up the cam should not be touching the idle screw. When warm the idle screw should go back to it's home position.
I would think you would need to have your fast idle hooked up so that when you push and pull your choke it should also control the fast idle.
Just a note: with the fast idle hooked up correctly I think you will need to mash the gas pedal a little when you pull the choke out or you will strain the cable adjustment.
Old Feb 23, 2010 | 07:03 PM
bigland's Avatar
bigland
right now the fast idle cam is not hooked up! Im wondering if I adjust thww curb idle up a little will it be enough . normally dont drive it it cold weather
Old Feb 23, 2010 | 08:19 PM
amish77's Avatar
amish77
won't idle as in chokes down and dies, or won't idle as in revvs up a lot? Just trying to narrow it down.
Old Feb 23, 2010 | 08:25 PM
bigland's Avatar
bigland
Just dies out no rev up. it seems like its idled down way to much. Should I have left the Fast idle cam on, It got hooked up sometimes and didnt work well with the manual choke.
