7.3 no start/ rough start
Did you run a buzz test?
Did you run a contribution test?
Did you check the engine oil level?
Are you keeping the fuel tank well above 1/4?
Did you visually and physically check every engine plug all the way back to the IDM and PCM?
Battery up to the task?
Battery cables in amazing condition visually and physically?
Did you unwrap looms and check several inches back into the harness on both sides of plugs??? Eyeballs and fingers!!
Biggest....
OEM sensors and control items from the Ford or International counter guy?? There are only a few online places to get your stuff that are trusted, never cramazon, Fleabay, or the corner store. This rule must never be broken.
Biggest....
everything appears to be in order. Last night I did a good cleaning of the battery terminals and made sure everything was tight. I did discover my glow plug relay went bad and one stud was loose internally and getting extremely hot. I replaced that as well and now the only code is for my ECM. I’m probably going to order a new ECM it just doesn’t make sense why that’s bad unless that relay shorted out and fried it
