Loosing options
Old Oct 21, 2023 | 05:13 PM
bc75's Avatar
bc75
Loosing options
I have a 99 navigator i changed my seats from a 03 expedition so i lost my power seat module. But the same time i lost my mirrors and keyless entry. Now my radio and electric widows stopped working. Is this just a coincidence? A few years ago i had to replace my windshield because when it rained my gauges and lights went crazy. Could my GEM module be the problem ?
Old Oct 21, 2023 | 10:03 PM
bc75's Avatar
bc75
Just noticed my interior lights aren't working.
Old Oct 21, 2023 | 10:06 PM
Truckwardo's Avatar
Truckwardo
You can't remove modules. Now it doesn't have all the data it needs for the seats and restraint system. And you have disrupted the CAN network.
Old Oct 22, 2023 | 04:54 AM
bc75's Avatar
bc75
That's what i was afraid of. Its been a couple of weeks since i changed seat. So i thought i was in the clear. Now I'm slowly loosing options.
Old Oct 22, 2023 | 05:09 AM
Truckwardo's Avatar
Truckwardo
Where is the old module? If you can just put it back in and adapt it to the new seat it should resolve those issues. The motors and seat heater should almost the same. And the passenger seat sensor should work also. For the SRS. Allowing you to hunt down other. The CAN bus must have all its moduels intact. Or the computer must be told what's happening. Also have you don't your ground inspection? On all the ground point? Corrosion on grounds attracts demons and gremlins that haunt the truck. And ground straps are important. Those flat braided ones.
Old Oct 22, 2023 | 05:48 AM
bc75's Avatar
bc75
The seat wiring was different i just hooked the ground and power to the seat to get it to work. I put 04 seats in a 99 navigator. My first day off ill hook the module up. I was hoping the navigator was to old for the can bus system.
Old Oct 22, 2023 | 05:51 AM
Truckwardo's Avatar
Truckwardo
Hopefully old enough to be tricked by just being plugged back in. Some new cars won't start if a door handle defroster shorts out.
Old Oct 25, 2023 | 03:40 PM
bc75's Avatar
bc75
Figured it out my fuse box was corroded. Watched a guy on youtube on how to take it apart and clean it. When i got it back together it started blowing the fuse for radio and dome lights. Found the light under the hood was blowing it. Took it apart and cleaned it. I guess it was so corroded wasn't getting enough power to blow the fuse.
afonda
Oct 19, 2021 09:03 AM
suggie
Oct 24, 2016 01:48 PM
Broncojohn
Feb 20, 2014 09:45 PM
buffalocomputer
Escape & Escape Hybrid
Nov 7, 2012 01:02 PM
JHadds
Jul 2, 2012 03:00 PM
