PSOM repair
Old Oct 19, 2023 | 08:05 PM
427 fordman's Avatar
427 fordman
PSOM repair
What is the place you all recommend for psom repair? Not my good 97, but my "well used" one needs it. Once in a while it won't shift, or sometimes the speedometer doesn't move either. Smack the dash and it works fine. Pretty sure that means it's time for a rebuild.
Old Oct 19, 2023 | 09:07 PM
John11.25's Avatar
John11.25
I used clusterfix.net, few years ago. Had to send my old one back for a core refund. It solved my shifting problems when nothing else would. They are located in Washington State.
Old Oct 20, 2023 | 07:57 AM
DJSTRAIT21's Avatar
DJSTRAIT21
Trailering
I used them as well, worked out great for me. Been working fine for a year now
Old Oct 21, 2023 | 04:31 PM
427 fordman
Didn't they just fix yours so the mileage was correct? Just asking. Thanks guys.
Old Oct 21, 2023 | 05:32 PM
Hit Man X's Avatar
Hit Man X
Apparently super easy for under $10 to DIY if you have time. After seeing that engine build of yours, I am confident you could do it easily.
Old Oct 21, 2023 | 05:36 PM
John11.25's Avatar
John11.25
As best I remember, I was in contact with them and indicated my mileage to be programmed in to a rebuilt PSOM.. They sent me a rebuilt unit with correct mileage. After swap out and install of new one, I sent my old one back for a core refund.
That way I wasn’t driving without instruments while mine was repaired.
It worked out for me, and unit still works fine. Mileage on odometer is still accurate.
Old Oct 21, 2023 | 05:40 PM
Hit Man X's Avatar
Hit Man X
Very good to know. I have other junk to drive so no skin off my nose.
Always plus when folks offer a core, if you will.
Old Oct 21, 2023 | 06:59 PM
427 fordman
Do you happen to have a link or directions? I don't have a problem with any mechanical work, the electrical side of things isn't my specialty. Thanks.
Old Oct 21, 2023 | 07:00 PM
427 fordman
Thanks again. If I go with an outside repair I'll be in contact with them. I do have other vehicles too, I could be down for a bit. But, if i can do it myself cheap i may try that.
Old Oct 21, 2023 | 07:36 PM
John11.25's Avatar
John11.25
I have watched this video of someone repairing the PSOM circuit board, it looks like brain surgery to me.
Old Oct 21, 2023 | 10:53 PM
NM76F150's Avatar
NM76F150
https://modulemechanics.com For me. Quick turn around , great service.
Old Oct 22, 2023 | 01:35 PM
Hit Man X's Avatar
Hit Man X
I will look for a few links for ya.
Old Nov 13, 2023 | 04:09 PM
427 fordman
I decided to go with this place. Faster service with the same price, more or less. Very happy. The truck shifts so much better. I just got it done and only drove a little bit but can tell the difference.
Ed in Maine
Oct 26, 2022 08:18 AM
Pete Hamstra
May 25, 2019 02:31 AM
johnfowler25
Jul 3, 2016 02:04 PM
Plumbing2012
Jun 6, 2013 07:06 PM
redbaron
1997 - 2003 F150
Jul 29, 2007 03:16 PM
