Sponsored by: Real Truck
Leaking coolent
Old Oct 19, 2023 | 10:24 AM
sprite1823's Avatar
sprite1823
1st Gear
Leaking coolent
I have a 2011 f250 with 159k miles just been in the shop to fix codes and filters was changed. With no leaks with anti freeze. Until after I came back from the shop. There is a big pool of coolent sitting in the valley of the engine and it drips down constantly after driving. The car doesnt over heat and runs fine. It seems like the pool is right under the turbo. Is my turbo leaking coolent? Does coolent go through the turbo?
Old Oct 19, 2023 | 10:34 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I don't believe coolant goes through the turbo, just oil.
What did they work on? If they had any coolant passages opened up, then they didn't seal it properly when they put it back together.
I would honestly take it back to the shop that worked on it and have them look it over, unless someone else messed with it it shouldn't be leaking.
shield1978
Dec 5, 2013 03:03 PM
ladbak1
Apr 22, 2013 02:05 PM
Norton72
23
Nov 5, 2008 06:38 PM
BlackF350rocks
Mar 6, 2007 09:10 PM
ncfirefighter46
North Carolina Chapter
Jan 13, 2007 09:20 AM
