Crank no start
Old Oct 25, 2023 | 02:39 PM
  #46
Auzcole's Avatar
Auzcole
Originally Posted by S-squatch
Assuming you have 5v ref means your pcm is running and functioning enough to send it, you should have a wait to start light.
I know my pcm is running and working because I pulled codes from it but I still have no wait to start or any other dash lights besides the battery
Old Oct 25, 2023 | 03:11 PM
  #47
S-squatch's Avatar
S-squatch
You can pull the cluster and test there. You are going to need a multimeter to know what voltages you are getting to go much more into this. But assuming all voltages are good, you have all good power and grounds at the pcm connector, it's sending a good 5v ref but no wait to start. I would say bad pcm.
maybe someone else is seeing something I'm missing.
Old Oct 25, 2023 | 03:20 PM
  #48
Auzcole's Avatar
Auzcole
ok in my cluster what do I test sorry really just don’t know and how many volts am I looking for
Old Oct 25, 2023 | 03:40 PM
  #49
S-squatch's Avatar
S-squatch
Wait to start is blk/pnk looks like it's a ground, red/yellow is power to the cluster.
if you aren't getting any cluster lights take a good look at that connector.
Your looking for system voltage on most of this, 5v ref you are looking for 5v. If you can't manage near 5v on the ref you could have bad grounds or power to your pcm.
I'm trying to go to easier things before back probing the pcm connector because I hate getting at that thing.
Old Oct 25, 2023 | 04:08 PM
  #50
Auzcole's Avatar
Auzcole
thank you I will get to it as soon as possible and let you know
Old Oct 26, 2023 | 03:40 PM
  #51
Auzcole's Avatar
Auzcole
ok so I am gettin 5v to the wait to start wire the cluster power is getting around 11 where can I find a diagram for the dash cluster wires because someone has done some weird wiring back there
Old Oct 26, 2023 | 06:44 PM
  #52
RacinJasonWV's Avatar
RacinJasonWV
Tech folder (sticky at top of our forum) has a section on wiring diagrams. Not sure if it has what you’re looking for.
https://www.ford-trucks.com/forums/1...l#post19537510
Old Oct 29, 2023 | 02:53 PM
  #53
Auzcole's Avatar
Auzcole
Well I tested to the best of my ability the wiring to the cluster and I was getting 5v to my wait to start Wire so I replaced the dash and now have another light the airbag light on but still no wait to start do I need to pin out my pcm to make sure every ground and hot is getting power or pin out the dash cluster wiring
Old Oct 30, 2023 | 02:08 PM
  #54
S-squatch's Avatar
S-squatch
How are you testing that, it should be a ground. New plan go with an incandescent test light. Go to batt + and back probe that wire then turn the key on. I'm guessing it's not going to light and you have ground problems to the pcm.
Old Oct 30, 2023 | 03:14 PM
  #55
Auzcole's Avatar
Auzcole
I tested it by having it plugged in to my cluster and the black and pink wire has a splice and a connector on it so I just turned the key on and struck the red into the connector and the ground on a ground and it read around 5v I can try your way sometime and see what I find
Old Oct 30, 2023 | 03:41 PM
  #56
S-squatch's Avatar
S-squatch
You can Google voltage drop test to understand that better, but that is a bad ground circuit You can check at least one pcm ground near the master cylinder on the fender. I'm not sure if there are any others I would need to look through diagrams.
edit to say always check your meter connection to make sure that was good.
Old Nov 1, 2023 | 02:12 PM
  #57
Auzcole's Avatar
Auzcole
I figured out my problem my fuse box was not making good connection thank y’all
bicounty
16
Aug 11, 2023 11:01 PM
roboford
Apr 29, 2023 10:29 PM
GriffinB
Mar 14, 2023 05:07 PM
Cam (didit)
6.4L Power Stroke Diesel
Nov 11, 2021 05:01 AM
M.Lusk
1997 - 2003 F150
Jan 31, 2021 08:57 PM
