Crank no start
Old Oct 18, 2023 | 07:00 PM
Auzcole's Avatar
Auzcole
Crank no start
I have a 1999 crank no start just replaced the pcm , it will fire off of ether for a second then stop , on my dash the only light that comes on is the battery light, rpm’s do not move also
Old Oct 18, 2023 | 07:44 PM
Wes444's Avatar
Wes444
Oh boy...
First off stop using ether. If the glow plugs are working correctly they will ignite it before top dead center, then you're replacing real expensive stuff. Leave the ether for your 80s lawn mower
If you don't have the wait to start light there's no point in cranking, nothing will happen without it. Unplug the fuel bowl heater/water in fuel sensor from the fuel bowl. It's the only thing that goes to the fuel bowl, right above the IPR. Replace fuse #30 under the dash, even if it tests good.
If you still do not have a wait to start light replace the relay for the IDM under the hood in the big fuses' box. Just swap it with the one for your HVAC blower for now to diagnose if that's the failure
Once you get a WTS light we can diagnose some more if you still have a no start
Old Oct 18, 2023 | 08:04 PM
Auzcole's Avatar
Auzcole
Originally Posted by Wes444
Oh boy...
do you know why I don’t have any other dash lights
Old Oct 18, 2023 | 09:14 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Wes44...... I got your back on this one.
Fix the WTS as stated. Nothing will work without the PCM.
No PCM no WTS.
No PCM no other lights will work as the PCM controls them.
As stated.. Fix the WTS issue then the rest will get worked out after.
And make darn sure the batteries stay topped off or you will have other issues. Use a real charger.
Old Oct 18, 2023 | 09:37 PM
Wes444's Avatar
Wes444
Yep.
What was the initial problem that led you to replace the PCM?
Your batteries need to have 10.5 volts while cranking in order for the PCM to tell the IDM to fire the injectors, assuming you have over 120rpm while cranking. But all that is moot without a WTS light
If you replaced the PCM and that wasn't the problem to begin with you are still at square 1. It could be a bad battery cable, bad ground at the block, bad battery terminal, blown #30 fuse, bad IDM or PCM relay (these are becoming a common issue as our trucks are aging together) a bad ground at the dash, a burned out WTS bulb throwing off the diagnostic steps, or a couple other issues.
Our problem is we can only help based off the info you give us, the legwork is up to you, but we're more than willing to share knowledge and get ya going again
Old Oct 18, 2023 | 11:20 PM
Auzcole's Avatar
Auzcole
Yep.
I have tried all the fuses and replaced them still no wts where now
Old Oct 19, 2023 | 07:30 AM
BillyBob69's Avatar
BillyBob69
I will second the No Ether advice.
As for the 30amp fuse, that circuit also powers the fuel bowl heater. So if the heating element shorts, it blows the fuse as it should but also pulls power to the PCM.
if the 30 amp fuse keeps blowing, unplug the fuel bowl heater. At the back/bottom of the bowl. Then replace fuse and see if it still blows when the ignition is turned to run. Don't need to crank.
Old Oct 19, 2023 | 10:06 AM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
I 3rd no either. Use WD-40 instead. I always recommend you unplug the bowl heater and leave it unplugged because I have seen too many times that the fuse did not blow when it shorted causing the PCM to get fried. I would also check the PCM for any bent pins because this is a common issue I have seen over the years.
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Oct 19, 2023 | 01:45 PM
Auzcole's Avatar
Auzcole
I have checked fuses and relays what’s next
Old Oct 19, 2023 | 09:25 PM
Wes444's Avatar
Wes444
Have you unplugged the fuel bowl heater? And leave it that way
Have you tested the diode in the large under hood fuse box?
Have you inspected/cleaned the block grounds from the battery?
Is your PCM ground clip installed inside the black plastic box that holds it?
Are you sure you got the PCM plug aligned straight and is correctly tightened all the way?
Have you unplugged the PCM and checked over each individual pin inside the plug to make sure none are bent over?
Old Oct 19, 2023 | 11:31 PM
Auzcole's Avatar
Auzcole
fuel bowl heater is unplugged ,tested diodes and relays and pcm is connected and no pins bent
Old Oct 20, 2023 | 06:56 AM
Dan V's Avatar
Dan V
Try swapping the IDM relay and the blower motor relay.
Old Oct 20, 2023 | 10:04 AM
Auzcole's Avatar
Auzcole
I tired to switch it with idm and the pcm still no luck I know I am getting power to the pcm I was able to pull codes from it and I tested the hot pin inside the connection
Old Oct 23, 2023 | 05:38 PM
Auzcole's Avatar
Auzcole
Crank no start
Ok so I have a 1999 with a no wait to start the only thing on the dash that works is the battery light everything else does not ,no fuel no oil, no temps nothing , I have replaced every fuse connected to the pcm idm and the cluster the relays are all good the diode is good I have power to the pcm it’s self I was able to pull codes from it and tested the hot wire inside of it , I have fixed battery cables have the voltage needed , I need help I don’t know where to go next
Old Oct 23, 2023 | 08:58 PM
Veteran: Navy
Some folks just want to find the one guy to post this.... Today I am that guy...
Stop throwing parts at it and do what we asked previously. Let us know what you have in detailed answers to what we asked previously.
We need specific parameters and numbers... Fixed or changed or spec tell us absolutely nothing. You were given several things to look at and do and your responses were worthless at best.
Starting a new post with the same issue will get you nowhere.
