U-joint ID
Old Oct 17, 2023 | 06:28 PM
hjartland's Avatar
hjartland
U-joint ID
My truck is a 1993 F-150 4x4 351W E4OD Dana 44 TTB diff & 8.8 rear diff.
What size u-joints do I need?
Took all 4 D/Su-joints out. Tried measuring with my calipers but the results were questionable.
I've seen listings for 1.063", 1.125",and 1.25" ... if I remember the numbers correctly.
I think they are all 1.063". Does that sound right??
Old Oct 18, 2023 | 05:14 AM
manicmechanic007's Avatar
manicmechanic007
Yes, the ones with U bolts at the rear flange take the middle size and the HD 3/4 tons and up take the biggest one
The ones that have bolt up flanges have the smaller caps
I would look for OEM Ford or Spicer u joints
The Spicer 5-213X should be the one you need
The newer ones have no grease zerk and they say they are more HD
Not sure I believe that
Note
The zerk needs to be on compression for ultimate strength of the star (drag racing)
If the zerk hole is getting pulled open, the star breaks easier under load
Old Oct 18, 2023 | 10:06 AM
dremtofford's Avatar
dremtofford
i need u joints for the front driveline on an 88 f150 4x4 tried looking it up on rock auto and got five different sizes. i probably should change them all while I am in there. but what size do I get.
Old Oct 18, 2023 | 10:32 AM
1Butcher's Avatar
1Butcher
One of my things on my list is to replace all the u-joints in my 2WD F250. I checked with my supplier and found there are several different versions and sizes. I have accepted the fact that I must remove them all, measure them all, order them, then install them. Sounds like this 2 hours job could take me 2 weeks of getting the wrong parts.
Good luck with your endeavor.
Old Oct 18, 2023 | 09:39 PM
hjartland's Avatar
hjartland
Decided to look at the driveshafts from my 1994 of the same specs.
The 94's results: (note 94 NOT the 93)
Rear D/S
Axle flange: 1.063
D/S rear: 1.063
D/S front: 1.063
X-fer case: 1.063
Front D/S
X-fer case: 1.125
D/S rear: 1.063
D/S front: 1.063
Axle: 1.125
Old Oct 24, 2023 | 05:23 PM
hjartland's Avatar
hjartland
Got
Got all 7 u-joints. Hope to put them in this weekend.
Moog for the front driveshaft and axle, Dana for the rear driveshaft.
Will let you all know how it goes.
Seanmac1007
Oct 2, 2023 06:11 PM
FordBoypete
Oct 2, 2004 12:42 PM
brannma
Nov 16, 2003 12:43 AM
popman
Apr 27, 2003 01:33 PM
rsjohnsn
Aug 12, 2002 05:31 PM
