88 5.0, 4sp. 75k.
Recently acquired this truck and was told it had sat for a while and it wouldn't start and needed a fuel pump. Well I ended up dropping and cleaning both tanks, replaced the forward tanks fuel pump and replace the fuel selector valve and the filter.
Truck fired up with new gas. Idled nice and smooth. Just touch the gas pedal and it would die like someone turned the key off. If you got off the pedal fast it would recover and idle. if you stabbed the pedal several times it would rev up as you got OFF the pedal.
I installed a new TPS and problem solved. I haven't driven the truck yet and I'm sure I'll find more stuff to fix, lol.
Well the "no start" problem turned out to be "only starts on the rear tank". Had to fix the fuel delivery. But when it did start it would die if I touched the throttle.
