Aerostar Ford Aerostar
heater.
Old Oct 17, 2023 | 05:06 PM
zenish's Avatar
zenish
heater.
on my 4.0 1991 xlt the front heater/defrost blows out cold air.the rear heater works well.any ideas?
Old Oct 18, 2023 | 10:25 AM
Jose A.'s Avatar
Jose A.
replace the front Heater Valve. The rear valve is still good. If system goes to defrost only, then check the plastic vacuum tubing around the fan box that is routed to the Heater valve, to a port in the engine, to the vacuum tank, and to the recirculate (MAX setting) valve mounted to the side of the fan / air box. The plastic tubing gets brittle, cracks, and vacuum is lost, making the system default to Defrost only.
Old Oct 18, 2023 | 01:17 PM
zenish's Avatar
zenish
i just did a little further research.the back heat temp stays hot regardless on what the dash temp lever is set on.the dash heat control does turn both front and rear blowers on and off.the front heat goes from warm to slightly warmer[at 195 degree engine]with the temp lever.
Old Oct 19, 2023 | 10:42 PM
xlt4wd90's Avatar
xlt4wd90
The heater control valves defaults to "on" with no vacuum. The front may be getting partial vacuum, while the rear is getting none. Sounds like loss of vacuum to me, similar to what Jose described.
KCB68
Aug 28, 2022 07:10 AM
Al Yelton
1997 - 2003 F150
Nov 23, 2021 11:16 AM
TWODOGS522001
Jan 17, 2012 09:42 AM
hipockets2842
1978 - 1996 Big Bronco
15
Dec 23, 2010 08:06 PM
cbfomoco
15
Oct 15, 2005 08:06 PM
