Advice needed.
Old Oct 17, 2023 | 11:11 AM
Oilfieldscum's Avatar
Oilfieldscum
Advice needed.
So I did my first axle ujoint on the swamper side on the weekend. It was horrible could not get the caps out, finally got it after lots of beating and cutting the ujoint. Now I put it all back together and when I spin the front drive shaft, the drives slide ujoint spins nicely and the swampers side, the side I did doesn't want to turn or is very difficult to turn. When I go and turn it I can barely turn it by hand. What did I screw up? And is it safe to drive in 2wd for now as it's my work truck.
Old Oct 17, 2023 | 11:41 AM
Kwikkordead's Avatar
Kwikkordead
Something is bound up somewhere. Hard to say without it being in front of me.
Old Oct 17, 2023 | 11:54 AM
Oilfieldscum
Something like what? What are the possibilities? I can spin it by hand, but just barely. Is there anything you can mess up when putting it into the diff? is it a seal or something that's bound and tight?
Old Oct 17, 2023 | 11:55 AM
Kwikkordead
Spin what by hand? The axle bearing? The u-joint at an angle?
Old Oct 17, 2023 | 12:00 PM
Oilfieldscum
The ujoint itself, it's all back together, so like the whole axle. Before, if I spun the front driveshaft, they would both spin freely if the hubs weren't locked. Now, with hubs unlocked when I spin the driveshaft, that axle doesn't wanna spin. If I go over and spin the ujoint/axle by hand, I can barely spin it.
Old Oct 17, 2023 | 12:01 PM
Oilfieldscum
Old Oct 17, 2023 | 12:03 PM
Oilfieldscum
The hub spun nicely before I put the tire on I checked that.
Old Oct 17, 2023 | 12:34 PM
John in OkieLand's Avatar
John in OkieLand
if the Seal is pressed in too far, it will have friction against the bearing, and eventually wear out and leak
that is why, a special tool is made to press in the seals
Old Oct 17, 2023 | 12:42 PM
Oilfieldscum
Like the knuckle seal? The big Seal by the hub?
BstevieG
May 16, 2019 08:11 AM
Quinnbristow
Apr 13, 2016 04:24 PM
Bonanza35
Jan 28, 2014 03:32 PM
T.McG
Offroad & 4x4
Jun 8, 2008 09:35 PM
AKFord
Feb 18, 2003 07:38 PM
