Front axle & drive shaft
Have a question for those that have worked on these. My 99 F350 4x4 cc lb.
I was under the truck today and turned the front drive shaft, the front axles turned but I could hold them while turning the drive shaft and they would not turn, I thought as long as the drive shaft turned the two axles should also turn. I ask because I can put it in 4x4 and I can feel the difference but when asked to pull hard either front wheel turns. I thought the front axle and front drive shaft should be locked together, at least one of the wheels. Thanks for the help a head of time guys.
Clux, I'm talking front end. I turn the drive shaft and both turn but, I can hold one from turning and the drive shaft still turns. And I can do this on either side, I haven't tried to hold both at the same time because I don't have enough hands. I'll have to get help to try this. My back work great its just the front.
Steeve
09-04-2002 02:03 AM
