Stalling problem solved
Old Oct 16, 2023 | 06:21 PM
Uni Moe's Avatar
Uni Moe
88 5.0, 4sp. 75k.
Recently acquired this truck and was told it had sat for a while and it wouldn't start and needed a fuel pump. Well I ended up dropping and cleaning both tanks, replaced the forward tanks fuel pump and replace the fuel selector valve and the filter.
Truck fired up with new gas. Idled nice and smooth. Just touch the gas pedal and it would die like someone turned the key off. If you got off the pedal fast it would recover and idle. if you stabbed the pedal several times it would rev up as you got OFF the pedal.
I installed a new TPS and problem solved. I haven't driven the truck yet and I'm sure I'll find more stuff to fix, lol.
Old Oct 24, 2023 | 01:12 AM
TexasGuy001's Avatar
TexasGuy001
At least it was a simple fix. The TPS would have been one of my first guesses too.
Old Oct 24, 2023 | 06:11 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Is this the solution for your “No start” thread?
Old Oct 24, 2023 | 06:27 PM
Uni Moe's Avatar
Uni Moe
Well the "no start" problem turned out to be "only starts on the rear tank". Had to fix the fuel delivery. But when it did start it would die if I touched the throttle.
kurt5153
29
Jul 21, 2010 10:16 PM
psu152
Apr 29, 2009 07:36 PM
putz54143
Dec 2, 2008 07:58 PM
BigDmoney
Jan 29, 2006 09:00 PM
Dustin_86
3.0L V6
Mar 19, 2005 04:37 PM
