pedal acting up again
Old Nov 30, 2008 | 09:36 PM
putz54143's Avatar
putz54143
fuel pedal was acting up again today two different times started put in gear and nothing just idle stepped on it a few times and away we went. i did get the fpr shimed up now it at 75 psi and i lost my kitty this weekend. hopeing the pedal holds up tomarrow its snowing and i have alot of plowing to do.
Old Dec 1, 2008 | 11:58 AM
MikeFromShiloh's Avatar
MikeFromShiloh
Mine has been like this for several yrs. Most of the time it only does this when the outside temp is cold. When the truck is first started, all it does is idle. A few quick "pumps" to the fuel peddle while idling and she will come alive. After starting and the fuel peddle is responding, it has never given any problems till the next start up. And mine does not do it ever start.
I figure the peddle assembl needs to be replaced but have not purchased one yet.
good luck
Old Dec 1, 2008 | 12:28 PM
Neal 97 250's Avatar
Neal 97 250
Mine does it when it is bitter cold outside. A few minutes of warming up and it starts to work.
Is this in the programming?
Old Dec 1, 2008 | 09:55 PM
Jaaaaaaackman's Avatar
Jaaaaaaackman
Had the exact same problem and solved it by taking the the switches off the pedal and sprayed them with contact cleaner from Radio Shack then literly sat down for an 1 hour or more and kept working the switch, have not had the problem since,,,,,,,,,,,, if you seach my threads you can find my pedal troubles over 1 year ago.......
BTW a new pedal assyembly was 770 dollars at the dealer...
Old Dec 2, 2008 | 06:55 AM
MikeFromShiloh
770 reasons it has not been replaced.......
Old Dec 2, 2008 | 07:58 PM
putz54143's Avatar
putz54143
ya i was going to get one through work but it was $400.00 so ill just try cleaning it
Johnboy1989
General Automotive Discussion
Dec 17, 2016 11:04 PM
norust
Nov 17, 2016 09:20 PM
carlspeed
Feb 5, 2015 12:02 PM
dclack
Aug 4, 2011 01:07 AM
fitmonkey1219
Oct 18, 2006 11:30 AM
