Ignition coil
Old Oct 15, 2023 | 06:03 AM
A thony's Avatar
A thony
4wd Low
Ignition coil
I'm fixing to replace my distributor and everything I've read says to run the wire to the negative post on my ignition coil but my original one is wired to the positive side which should I do up until a few weeks ago the ran great
Old Oct 15, 2023 | 08:50 AM
440 sixpack's Avatar
440 sixpack
It will run either way.
Normally you want the power source hooked to the + side of the coil.
Old Oct 15, 2023 | 08:53 AM
A thony's Avatar
A thony
4wd Low
I think I'm gonna try switching mine and see if it runs any better thank you for the advice
Old Oct 15, 2023 | 09:43 AM
440 sixpack
If you change the coil the most important thing is if you get an internal or external resistor coil.
Old Oct 15, 2023 | 09:51 AM
A thony's Avatar
A thony
4wd Low
How do I know which one I need
Old Oct 15, 2023 | 09:38 PM
440 sixpack
Assuming everything is original you need a non-resistor coil. if someone has messed with it you might need a resistor coil.
Old Oct 16, 2023 | 08:22 AM
jtrux's Avatar
jtrux
It's been a while BUT with ignition on, grab your voltmeter and see how many volts are on the positive side of the coil wire. If it matches the battery, get a resisted coil, if it is reading something like 9 or so, there's a resistor built into your harness somewhere and you need the unresisted coil.
Old Oct 16, 2023 | 09:09 AM
440 sixpack
Correct, except some aftermarket systems require 12v to the coil.
95obsford
May 20, 2023 07:17 AM
T&C G
21
Aug 19, 2020 06:13 PM
fordboy300
May 12, 2011 10:14 PM
tiredone
May 17, 2006 10:36 PM
fordtrck302
Electrical Systems/Wiring
Jun 23, 2002 04:22 PM
