Knock sensor
Old Oct 14, 2023 | 09:04 PM
kenny nunez's Avatar
kenny nunez
Question Knock sensor
I have a 94 F150 with the 5.0 mass air version that is cracked. I got a 5.0 which is speed density from a 94 F250. The knock sensor was screwed into the rear top of the block behind the manifold with a 1/2” 13 thread on the cracked engine. The engine from the F250 does not have a threaded hole in the block in the same location. Has anyone ever ran into this? So far every sensor that I have looked up is 1/2 13, all the holes I have seen so far in the heads and block are smaller.
Of course I will using all the mass air controls and sensors on the replacement engine.
Old Oct 14, 2023 | 10:37 PM
jas88's Avatar
jas88
You could just drill a hole in the new one and tap the hole.
Old Oct 15, 2023 | 07:06 AM
rla2005's Avatar
rla2005
Are you sure the donor is a 5L?
Old Oct 15, 2023 | 08:49 AM
dremtofford's Avatar
dremtofford
my connector broke on my knock sensor as I was taking it off. all the replacement ones are square and my sensor is round.
crimson5liter
Apr 17, 2021 05:45 PM
Jeff Dodson
Jan 19, 2009 02:41 PM
Jusitinj608
Oct 3, 2007 10:49 PM
brix47
Jan 20, 2004 05:43 PM
runner
Dec 29, 2003 06:25 AM
