Knock sensor replacement
Old Dec 28, 2003 | 04:42 PM
runner's Avatar
runner
Hi All
Now that I have my tranny out of my 88 F250 302 5 speed due to clucth replacement, I noticed that I have a better view at the knock sensor. This sensor is way behind the engine block.. Need to rplace because the top is broken off.
Does anyone have experience getting this out and how is it done.
thanks,
Runner
Old Dec 28, 2003 | 09:02 PM
Slade901's Avatar
Slade901
I have not done Knock Sensor before but I've done CPS. Anyway the book states to just unscrew the Knock Sensor. You might need some wrench to take off or tighten it.
Old Dec 28, 2003 | 10:14 PM
tripndrag's Avatar
tripndrag
It just unscrews. I just replaced my engine, swaped to a Mustang shortblock and mass air conversion. The new block didn't have the hole for the knock sensor so I called FMS to inquire about what I should do. I removed it to check it out. It will be easy to install a new one in your block.
Old Dec 29, 2003 | 02:35 AM
BigSix1's Avatar
BigSix1
How Aout on the 300 Six?
All:
Does anyone know where the knock sensor is on the 4.9 six? I've got the code indicating a bad knock sensor and want to replace it.
Is it only possible with the tranny out?
Is there any way to test these things? I'd like to scavange one from a junk yard, but test it before I install the "new" one.
Peter
Old Dec 29, 2003 | 06:25 AM
runner's Avatar
runner
Peter,
Don't know how to test one. There a line that goes to mine and it's broke off. On my F250 302 you can see it behind the back of the engine block and could get access to it. I could see it alot better with the Tranny out and have better access. Don't think you have to have it out to do this.
Runner
turbodave89
2004 - 2008 F150
27
Oct 15, 2019 03:08 PM
BigBlueBomb
Mar 4, 2014 01:46 PM
carter2011
16
Jan 25, 2011 05:05 PM
candie5
2004 - 2008 F150
May 12, 2010 09:40 PM
runner
Jan 13, 2001 06:28 PM
