Carb throttle shaft binds when mounted
Old Oct 13, 2023 | 05:45 AM
LandAndStone's Avatar
LandAndStone
Desk Jockey
351M MC 2150
I am wrapping up my intake reseal job that included an intake refresh, EGR plate cleaning and new carb posts.
Last step is tightening down my 2150 to spec 14 lbs.
But when I tighten my carb mounting nuts, the throttle shaft binds - meaning hard to turn and won’t return when released. If I loosen the mounting nuts, the problem resolves.
I wonder if I am flexing the shaft somehow?
I removed the mounting gasket (thick version) and tested against the EGR plate - no issue. I retested with several different gaskets (thick) - issue returns.
Tightening order has no impact - only relative tightness. A few ft-lbs and it binds.
Possible obstruction on gasket carb mating surface? I tried my old gasket but still had the issue.
On the bench the carb operates smoothly. Same when mounted and not tightened.
Any one bump into this before?
Old Oct 13, 2023 | 09:13 AM
ranger140892's Avatar
ranger140892
Grumpy goat
Something is not flat. Either the mating surface on the intake manifold, or the carburetor flange. Use a straight edge and flashlight to determine which one. Or possibly both.
Old Oct 13, 2023 | 10:00 AM
Pickupmanx2's Avatar
Pickupmanx2
What he said ^^^ something is causing a bind, definitely pull off and check!
Old Oct 13, 2023 | 10:17 AM
tbear853's Avatar
tbear853
I use thinner carb to intake gaskets, as thick ones will compress more under nuts as they push up against no nut areas ... I grease my gaskets too. I also tend to go easy on torque and double nut my nuts. I doubt that I use a full 14 "torques" on them before the second nut..
I once used a thick gasket on a 302 EGR Mustang, busted the carb base.
But yeah, you have something "not flat" there, and those carb bases don't like to flex, so if binding ... check it close for a crack.
Old Oct 13, 2023 | 02:14 PM
beartracks's Avatar
beartracks
Mkaake sure the gasket hole isn't too small
Old Oct 13, 2023 | 09:07 PM
LandAndStone
Desk Jockey
Well I decided to use a thin gasket and call it a day. No issues.
I had a collection of 4 thicker gaskets. I tried each one individually. One of them was the prior gasket that worked previously. Everyone of them caused the throttle shaft to bind. Each was identical in size and manufacture.
Not sure. I don’t have a theory on this one. But I suspect Tbear is onto it with the compression of gasket,
Jghake
Jul 17, 2018 02:03 PM
lalberts
Dec 5, 2016 08:47 AM
lemasters f100
Jan 20, 2014 10:50 AM
Chumbucket
Mar 18, 2008 02:56 PM
chauss513
Feb 8, 2008 05:18 PM
