Shoot looks like they've discontinued the "original" RAD16 part number (like a bunch of other parts like oil coolers). Probably switched to a different supplier. I had purchased a RAD16 from RockAuto last year (April 22) and it was identical to my stocker.
The consensus I've gathered is there are not aftermarket options that will provide the cooling capacity of the stocker. Most have less fins/inch (giving less heat transfer area) and potentially less tubes, or different sizes tubes. I push my cooling system pretty hard during the summer so I stuck with stock. Also my original lasted over 15-years...
Plenty of guys out there running the Performance brand radiator (same one BPD sells) that don't seem to have issues, but I'm not sure how well they perform vs the OEM.
My only personal experience was purchasing a NAPA branded radiator first and upon inspection found the fins/inch count way less than the OEM so I returned it before installing/testing and went to the OEM.
Most dealers won't ship the OEM as they are very poorly packaged from Ford. Rock Auto adds some foam to the box and my arrived with minimal damage.
To add to Jester's advice, I went through a hassle years ago with my OEM leaking. I can attest that the OEM radiator has 92 cooling passages and the Performance Radiator all aluminum has 87 cooling passages. IMO the all aluminum cools just as good if not better than OEM in my opinion. The plastic tanks are the first to go on the OEM, and I can guarantee you'll never find an OEM like they were made 15+ years ago. I went OEM and had a leak right out of the box....obvious defect. Got pissed and bought an aftermarket OEM compatible and that hunk of junk leaked within 500 miles from the tank seal. Got sick and tired of the run around and went with Performance Radiator model 2944.....never one issue and I push my truck hard sometimes.
If I had to do it over again I would go with the all aluminum in a heartbeat.
Good luck
Joe, how much are you towing? What kind of grades and what ECT are you seeing?
I've ran all aluminum (no plastic end tanks) units from Radiator Express (link below) in a couple of trucks (including the 6.0 Excursion) with great results.
They have a few options, but the one I'm using in the Excursion is the $299 , all aluminum , heavy duty version.
