Sponsored by: Real Truck
6.2L Gas Issues and Fix (P06B6 Code)
Old Oct 5, 2023 | 02:01 PM
ARN 104's Avatar
ARN 104
4th Gear
I got my truck, 2015 F-250 XLT 6.2L a couple years ago with 44K on it and it ran good. Seemed a little gutless but I attributed that to the weight of the truck. More recently it's idle seemed a little bit off but hardly noticeable. Check engine light came on which surprised me because I big reason I got the truck was for reliability. None the less it is a machine so things happen. Bought a Bluetooth OBD2 scanner and got the code P06B6 (Internal Control Module Knock Sensor). Truck was running OK so I erased the code to see if it would come back. After a few days it did so I decided I'd start looking into it. Well, before I could take any action the trucks performance declined pretty rapidly, to the point I thought it might die going up a hill or at a stoplight. It sort of felt like the transmission was slipping but that didn't add up based on the code. I had done a little research and figured it was plugs/coils/wires or broken valve spring. A little more digging and I ruled out the valve spring based on startup noises compared to some videos on Youtube plus some threads on here seemed more in line with the plugs/coils/wires, especially given the volume of the ticking noise.
Took the truck to the shop and within a few hours they called saying how bad of a condition the plugs/coils/wires were in and that would send pictures if needed. I trust this shop so I decided to go ahead with the repair and I'll look at the old parts when I get it back. Got the truck back later that day and its performance had drastically improved. Seems obvious that it would perform better but I did not expect it to be that much better than when I first got it but it is more noticeable than I expected. I wish I could say I did the repair myself but I'm happy with the work the shop did.
I wanted to post this so if someone else is dealing with this issue, hopefully it helps them narrow down what might fix their truck.
g8rgar08
6.2L V8
May 5, 2022 11:31 PM
bones281
1997 - 2003 F150
Jan 16, 2010 06:14 PM
Trailblazen
Apr 8, 2009 03:50 PM
RAPTOI21
1997 - 2003 F150
Feb 25, 2008 07:58 PM
Slade1
1983 - 2012 Ranger & B-Series
Mar 11, 2003 01:39 PM
