Radiator differences
Old Oct 5, 2023 | 08:40 AM
Jakespeeds's Avatar
Jakespeeds
I am working on an electric fan project with ac AC condenser. Rather than take my truck apart and have it sit while I measure and build everything. I was going to buy a used radiator and use it. I found one locally from a bump. The owner says its from a 302 truck. I don't care about the fins I just need the frame of the radiator to be the same as mine. Which is a 69 with a 360. Are the radiators basically the same in the mounting and such?
Jake
Old Oct 5, 2023 | 05:34 PM
1browski's Avatar
1browski
Is the radiator out of a bumpside truck? This is just a guess on whether the same radiator was used with 360s and 302s but there were two different core supports. One core support was in the 4x4s and f350s which used a bigger radiator. The other core support was put in everything else and used the radiator like with your 360. So if the other radiator is out of a bump, it should mount directly to the face of the core support like yours.
Old Oct 5, 2023 | 10:34 PM
RichS2659's Avatar
RichS2659
F-350's could be had with either Super Cooling radiators and Xtra cooling radiators. 4x4's came equipped with either SC or regular/Xtra cooling.
https://www.fordification.com/partnos/fanshroud.htm
https://www.ford-trucks.com/forums/1660549-1969-camper-special-correct-radiator.html
Old Oct 6, 2023 | 08:10 AM
Jakespeeds's Avatar
Jakespeeds
I know it came out of a a bump. But I will have to ask which model. I appreciate the insight. Those are all points I never thought about.
Thank you.
Jake
Old Oct 6, 2023 | 08:19 AM
Jakespeeds's Avatar
Jakespeeds
Turns out its from a 1969 F100 with a 302. Mine is a 1969 F100 with a 360. So it looks like its the same as what I have if I read everything correctly.
Jake
Old Oct 6, 2023 | 12:01 PM
deckertd's Avatar
deckertd
I used this in my '71 250 Camper Special...Bored-Stroked to a 418ci
Radiator... https://www.jegs.com/i/Champion-Cool...CC433/10002/-1
Fan.....https://www.jegs.com/i/Speedmaster/7....1010/10002/-1
Wiring Harness...https://www.jegs.com/i/JEGS/555/10560/10002/-1
Basically bolted in and zero issues. Runs cool on 100 degree days. $380.00+ tax/shipping Main thing is ZERO issues to-date!
Dan
Old Oct 6, 2023 | 12:14 PM
Jakespeeds's Avatar
Jakespeeds
Dan,
Thank you. Its been my experience to use factory parts where possible. My electric fan is out of a Mercedes
https://www.am-autoparts.com/product...-36895685.html
The shroud is actually cast aluminum and these fans have been proven to be bullet proof. Plus they are very slim. It will allow me to move the radiator back to make it easier for my AC condenser and new trans cooler. If I do this right everything will be easily serviceable.
Jake
Old Oct 23, 2023 | 12:02 PM
DirtyFerd's Avatar
DirtyFerd
The answer is, it might be the same. I pulled a core support from a 72 with a 302 to go in 68 with a 360 and the radiator was smaller and so was the hole in the core support. The height was the same, it just wasn't as wide
Old Oct 23, 2023 | 12:58 PM
RichS2659's Avatar
RichS2659
There are 2 core supports and radiators to match: regular and Super Cooling/Xtra Cooling. The Super Cooling is wider.
As an example of fan shrouds:
67duster
Oct 16, 2013 11:54 AM
old broke prospector
Mar 7, 2013 01:01 PM
Jfrost
Sep 7, 2006 12:47 PM
marvinlong
Nov 22, 2004 08:06 PM
JTdesert
Offroad & 4x4
Jul 31, 2004 01:35 PM
