E40d problem
Old Oct 5, 2023 | 12:37 AM
Nick05's Avatar
Nick05
E40d problem
Just put a new reman trans(E40d) and new reman converter into my truck and it won't shift but feels like it gets to the rpm to shift then kinda feels like it wants to but at the last minute dosent if that makes sense. The instructions said to only put 1/2 a quart of atf into the converter and 10 to 14 into the trans pan. That dosent seem enough, could that be causing my problem. The truck also has a bank trans controller I belive its called but when I unplug it it makes the od light flash so assuming that's not my problem.
Any help is appreciated!
3rd break light works, new speed sensor
Old Oct 5, 2023 | 07:59 AM
z31freakify's Avatar
z31freakify
Sounds like it's low on ATF. Have you checked trans fluid when up to temp with engine running?
Old Oct 5, 2023 | 09:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What does your dipstick show? Always check with the engine running.
Old Oct 5, 2023 | 10:06 AM
Nick05's Avatar
Nick05
yeah I did just my dip stick is all bent and I can't find a replacement rn so it kinda a guessing game. Thanks for your help ill let you know if thats the problem.
Old Oct 7, 2023 | 12:31 PM
Nick05's Avatar
Nick05
A fuse was blown. Guess should always start at the basics
Old Oct 9, 2023 | 05:50 PM
oldbird1965's Avatar
oldbird1965
What fuse was blown?
Old Oct 10, 2023 | 07:24 AM
Bllslggr's Avatar
Bllslggr
Yes. What fuse was blown.
Old Oct 26, 2023 | 03:09 PM
Nick05's Avatar
Nick05
The fuse for the dome loght and speeddo. Sorry for the late reply didnt see the noitifcation. Its a 15 amp infuse number 8.
Old Oct 26, 2023 | 05:38 PM
Conner Stevenson's Avatar
Conner Stevenson
Was your dome light still working even with the fuse blown?
Old Oct 28, 2023 | 01:12 AM
Nick05's Avatar
Nick05
no it wasn't and it would sgift just would shift really hard to the point you could see the truck jerk when shifts. I just bought the truck and the guy said it need a new tranmisson and I was dumb and blindly belived him since he said he put a Facebook marketplace place special into it. (Trans when pulled out showed to have come put of a 1991 f250 was written on. Dont know how true it is) . Also has a rust spot above the dome loght so though water got into it making it not work. Pretty much sums it up.
vincepro911
Jun 22, 2012 02:25 PM
02sd
Oct 19, 2004 04:11 PM
RxF
40
Apr 12, 2004 08:06 PM
