So far I have changed every O ring on my fuel housing and just installed a new drain valve. It is still leaking fuel at the drain valve. Any ideas? I am starting to think I need a whole new housing.
I think Diesel Orings has a reseal kit for the OE one. The orings dry out and crack.
I've had mixed results with dorman, some have leaked out of the box on me so I stopped using them.
All I can say is remove the filter housing and give it a good examination. With a magnifying glass if need be. Don't remember exactly how it is constructed, but how about where the fuel bowl heater circuit goes through the wall?
it’s definitely dripping around the drain I can put my fingers under it and they are wet
