Fuel leak
Old Jun 27, 2007 | 06:51 AM
ecrailings's Avatar
ecrailings
Fuel leak
I have fuel dripping out of my engine. It was dark last night so I could not get a good look at the source, but there is a big pudddle on the manifold. I opened the fuel drain valve and reclosed it to make sure that it was all of the way closed but the leak is still there.
Any ideas or common problems I should look for?
TIA
Carter
Old Jun 27, 2007 | 09:27 AM
nlemerise's Avatar
nlemerise
I'd bet it is the o-rings on the drain valve...You can get them from a guy on eBay for $2-$3 delivered. I keep a set in my truck for the inevitable day...
Old Jun 27, 2007 | 09:38 AM
nodakford's Avatar
nodakford
Sounds like fuel drain valve o-rings. They are notorius for leaking.
Old Jun 27, 2007 | 09:39 AM
ecrailings's Avatar
ecrailings
I took it to the stealership.....They said they have to replace the fuel drain something or other...$350........yea, I know! They will have it ready in 2 hours though...hard to beat that. And considering I am in the middle of a job and have to get the materials there today!
Old Jun 27, 2007 | 11:02 AM
nlemerise's Avatar
nlemerise
"I took it to the stealership.....They said they have to replace the fuel drain something or other...$350"
This is an easy rebuild, in a matter of minutes, with about $1 worth of parts. I bet the dealer is just replacing the fuel filter bowl...get the old parts at least...then rebuild the drain and keep it as a spare. Please post the name of the dealership...they ought to be ashamed, but they aren't.
This is the reason I will not go to a dealer...this is unarmed robbery!
Old Jun 27, 2007 | 11:25 AM
1996pwrstrk's Avatar
1996pwrstrk
Ouch $350.00 when about 5 bucks and 15 mins. would have fixed it ..............
Old Jun 27, 2007 | 06:00 PM
ecrailings's Avatar
ecrailings
Well,
They said that after they fixed that leak there was another leak in a fuel hose /read mis-diagnosis/ and hit me for another $220.
The dealer is Universal Ford in Richmond, VA.
They said that because of the nw ulsd that I will have to add an additive to my fuel to keep the fuel system lubed or it will continue to keep failing. I am going to start a new post about this.
Groundpounder0331
Aug 28, 2023 03:16 PM
johnwassink
Apr 26, 2016 09:48 PM
High_HP
Dec 12, 2011 04:30 PM
1950gmcelc
Feb 28, 2009 02:54 PM
