Need 360 Camera Part Numbers 2017
Old Sep 28, 2023 | 09:54 AM
F2502011's Avatar
F2502011
All of my factory cameras are cloudy and essentially useless. Are all 5 the same camera or are they different? Where can I get the Ford part numbers for them? Or is there a better aftermarket option that is plug and play?
Old Sep 28, 2023 | 10:10 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is your truck covered under the foggy camera recall?
https://www.autoblog.com/2022/09/01/...-foggy-camera/
Old Sep 28, 2023 | 10:12 AM
F2502011's Avatar
F2502011
Yes, but that's just the rear and I don't want to take it in because then they'll do the emissions flash that doesn't sound like a positive thing so I would rather do it myself.
Old Sep 28, 2023 | 11:04 AM
4wd6.7L's Avatar
4wd6.7L
There is also a CSP (22M03) to include the front and side cameras too. If you tell them that you do not want the emissions recall performed on that visit, they shouldn't do it. Most of us found the emissions recall to be a non-issue. Not positive or negative.
Old Sep 28, 2023 | 11:18 AM
F2502011's Avatar
F2502011
I wasn't aware of CSP 22M03 that may change my decision to not take in. Anyone have a copy of the actual document they could post here?
Old Sep 28, 2023 | 11:20 AM
jimzpsd's Avatar
jimzpsd
You can search for p/n's here, seems e-bay has lots too
https://www.fordpartscatalog.com/v-2...body--tailgate
Old Sep 28, 2023 | 11:35 AM
4wd6.7L's Avatar
4wd6.7L
I haven't received the letter yet. Doing a Google search I was able to find a letter posted for the same CSP that was released to owners of other Ford and Lincoln models. The wording on part of it talked about reimbursement if cameras were replaced prior to the date on the letter.....that had me considering changing the front cam myself, and seeing if they will reimburse me for the camera purchase. It's a gamble I haven't decided if I'll try yet.
Old Sep 28, 2023 | 12:16 PM
redford's Avatar
redford
The emissions upgrade was a non-issue for me. Maybe I use a little more DEF, but the difference is so slight it just might be my imagination.
Old Sep 29, 2023 | 08:21 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
I just had all (4) cameras (bed camera not affected) replaced on my 2020 and my daughters 2017 under the recall !!!
ZooDad
reddogg94602
Nov 21, 2021 10:22 PM
jh225
May 31, 2007 09:24 PM
joeddavis
Jun 23, 2006 05:00 PM
flyflinger
Oct 24, 2005 02:37 PM
paulbunyan
Feb 18, 2002 12:02 AM
