4X4 won't engage
Old Nov 3, 2007 | 08:05 PM
hiwayman55's Avatar
hiwayman55
Smile 4X4 won't engage
I have a 1994 F150 XLT extended cab, short bed that I just purchased. I went to engage the 4X4 and all that happens is a relay kicks on, and kicks off. No light goes on and 4X4 does not engage. Please advise...
Old Nov 4, 2007 | 05:42 AM
alz's Avatar
alz
It sounds like the shift motor is not working. You may want to remove it and see if you can manually actuate the t-case. Shift motors are pretty common to fail on these trucks if not used often. You should try activating 4x4 once a month just to keep things feed up.
harzy_10
1983 - 2012 Ranger & B-Series
Mar 24, 2013 09:51 PM
Tacswa3
6.7L Power Stroke Diesel
Aug 28, 2012 06:13 AM
slotdoc56
Nov 14, 2011 01:02 PM
goodtobeeme
1997 - 2003 F150
Dec 28, 2010 05:44 PM
modeltford
Dec 2, 2006 11:39 PM
