E450 transmission with ebrake
Old Sep 25, 2023 | 08:38 PM
Drop low's Avatar
Drop low
4wd Low
Hey guys, I'm looking for some info on replacement of my 4R100, my unit is a 2000 e450 2wd transmission with ebrake.
from my understanding these are just regular 4x4 transmissions with the brake bolting up where the transfer case would, my local wrecker is saying that theres so many different options and i have a line on a rebuilt 4x4 tranny i would like to purchase, any info would help.
Old Sep 26, 2023 | 08:18 AM
manicmechanic007's Avatar
manicmechanic007
Post a picture of yours
I believe you are correct (so is the wrecker guy)
So, the difference used to be the tail shaft length and possibly the case
Call a few trans shops?
Pull your E brake off and see what your shaft and case looks like
Compare that to a 4x2 trans with the tail housing removed (and a 4x4 one)
I think you might be right, and you will be needing the 4x4 one
Mark might know, hopefully he will chime in
Old Sep 26, 2023 | 09:19 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It is a 4x4 trans. You need to match the engine. The transmissions are different with different engines.
Old Sep 26, 2023 | 06:19 PM
Drop low's Avatar
Drop low
4wd Low
yes, it's a 7.3 so 6 bolt tc. I just finished reading an old 2020 thread that someone had similar questions, looks like I'm good with a 4x4 tranny for a 7.3l
ford change the numbers throughout the years but internals should all be the same only difference is 4x2 and 4x4 👍
IDI Diesel
Dec 17, 2011 06:21 AM
michael_d_h
Dec 31, 2008 03:22 PM
fun_suv
Apr 6, 2007 06:19 AM
sneak
Nov 22, 2004 06:22 AM
Ryan356
May 7, 2003 10:33 AM
