Bronco II Ford Bronco II
Plug/ Cap for oil level sensor
Old Sep 22, 2023 | 09:30 AM
Alvik's Avatar
Alvik
4wd Low
This oil level sensor at this point is obsolete, wire doesn’t work and is broken and frankly i can check the oil with the dip stick.
Does anyone know where to buy a plug/cap that i can use to block it off?
Has anyone done this before?
Old Sep 23, 2023 | 09:08 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I don’t understand. Install the sensor. Do not connect wire. Done.
Old Sep 23, 2023 | 09:18 AM
Alvik's Avatar
Alvik
4wd Low
Originally Posted by My4Fordtrucks;[url=tel:20984345
20984345[/url]]I don’t understand. Install the sensor. Do not connect wire. Done.
I would but it keeps leaking slowly, i’ve tried sealing it with different things but continues to leak, it’s just another place for oil to leak from & would be better to just block off.
Old Sep 23, 2023 | 12:00 PM
My4Fordtrucks
Have you tried replacing the gasket?
Old Oct 21, 2023 | 06:35 AM
My4Fordtrucks
Did you fix the leak?
Old Oct 21, 2023 | 07:23 AM
Alvik's Avatar
Alvik
4wd Low
Originally Posted by My4Fordtrucks;[url=tel:21011101
21011101]Did you fix the leak?
I did, So far so good i found the stock plastic gasket online for like $30 and that’s been working good.
It was a little different then the one you sent, instead it was smooth with a small rubber gasket on each side. but similar enough.
2006powerstroke90
Jun 23, 2020 03:44 PM
Firefighter 1406
Mar 19, 2015 07:27 PM
mblanken881
Mar 9, 2012 10:03 AM
Ken_C
Feb 16, 2011 07:38 PM
Gwilkrrs
Nov 9, 2003 06:52 PM
