2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Abs, traction, and brake light issues
Old Sep 15, 2023 | 03:47 PM
blueline970's Avatar
blueline970
OK so I have a 2010 Expedition Limited with 170k on it. Recently the abs, brake, and traction control would periodically come on and the info screen would say service advancetrac. Only code I have are p0130, p0150, and a b1324. A friend looked up the b1324 on a repair site I don't have access to and said to check the ground from abs module. I cleaned it and still have issues. The other two code I know are o2 sensors and there is a tsb in regards to that. Is there anything else I should be checking?
Old Sep 16, 2023 | 11:15 AM
aldridgec's Avatar
aldridgec
I'm betting this is one of those codes on the trouble tree that ends with "replace with known good module and retest". If verifying the power and ground doesn't work, that's probably all you can do.
Do you have a scan too that can access data on the abs module?
XbigXredX
Apr 4, 2019 11:44 AM
bashby
Sep 17, 2012 01:50 PM
kjester
15
Mar 17, 2011 02:31 PM
earl964
Nov 16, 2007 10:23 PM
