rust hole in frame
Old Nov 20, 2003 | 07:05 PM
rustorer's Avatar
rustorer
rust hole in frame
hi, i live in ny, salt on roads in winter causes rust big time. on a recent crawl under inspection of my f-250 , i noticed a rust hole the size of a golfball and weak around the edges of the hole, the hole is centered in the frame behind the passenger side rear shock mount and forward of the gas tank,is this a common area for rust? is it possible to beef it up with steel by welding or bolting it in, or time to part out my 79 f-250,if i do weld or bolt something in what would the local inspection station think of it?
Old Nov 20, 2003 | 08:18 PM
Ecuri's Avatar
Ecuri
The textbook says don't weld truck frames... they are hardened steel and will be weaker at the weld areas. However, many have reported welding with no adverse effects. I would choose the plate option personally. If the truck isn't worked/loaded hard, I would arrest the corrosion by grinding out the hole, phosphate and paint it and go about my business, personally. The area between the leaf-spring mounts isn't stressed nearly like the center span (cab to bed area). BTW, the state inspects your frame in NY????
jade79
Jul 13, 2017 09:44 PM
mwilliams0326
All Things Towing
Nov 22, 2015 04:31 PM
benbuilder
Nov 16, 2015 07:12 PM
burnettd01
Sep 17, 2015 12:43 PM
skonnie-mark
Paint & Bodywork
Aug 19, 2004 08:35 PM
