Is welded gooseneck hitch ok in '88 F350?
Old 11-19-2015, 10:57 AM
mwilliams0326
mwilliams0326 is offline
mwilliams0326 is starting off with a positive reputation.
I recently purchased a 1988 F350 DRW to pull my horse trailer. It was used by the previous owner also to pull a horse trailer. Upon inspection, I've noticed the gooseneck hitch is welded to the frame. I've always thought this was best attached by being bolted to the frame. Should I be concerned and can you add bolts in addition to it being welded?
Old 11-19-2015, 07:35 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
I would take it to a local hitch shop for visual inspection to be safe.
Old 11-21-2015, 12:01 PM
Irelands child's Avatar
Irelands child
Irelands child is offline
Irelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to beholdIrelands child is a splendid one to behold
If the welder did a good penetration weld, not a problem with that - but welding to a frame anywhere between suspension supports is a cause for concern and something that Ford tells you not to do. It can cause brittle spots on the frame steel if not done correctly, with a stick weld being the worst as far as any heat affected zone. Get it inspected by someone who is a certified welder for your safety.
Old 11-22-2015, 04:31 PM
superrangerman2002's Avatar
superrangerman2002
superrangerman2002 is offline
superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.superrangerman2002 has a great reputation on FTE.
I would'nt worry about it. Common practice back then....not necessarily right but certainly was done a lot on farms and construction sites.
Check for cracks and motor on.
Badger350
2017+ Super Duty
05-26-2017 09:44 AM
sundance1
2017+ Super Duty
12-24-2016 03:10 PM
klakak
2017+ Super Duty
10-26-2016 06:54 AM
horsebadorties
Fifth Wheel & Gooseneck RV Towing
04-13-2016 11:06 AM
Elhanan
Toy Hauler Towing; Fifth Wheel & Bumper Pull
15
02-29-2016 06:28 AM
Quick Reply: Is welded gooseneck hitch ok in '88 F350?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
