Thread Size - Bypass delete bolt
Old Sep 12, 2023 | 07:27 PM
Alexis Garcia's Avatar
Alexis Garcia
Made a rookie mistake, accidentally cross threaded the bolt for the bypass delete. For some reason was leaking after installation and tried tightening as much as possible and ended up cross threading the thread that’s in the transmission and the bolt
Anyone know the exact thread size or know of a kit that would help restore the thread?
When I took out the bolt a lot of metal shaving came along with the blot thread
Going to have to buy the diesel site bypass delete bolt since the stock one is no longer good either but would need a kit that would fix the thread that goes in the transmission
Old Sep 12, 2023 | 07:35 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Must be watching that blowhard "Custom Works" on Youtube.
I can't help you with thread sizes but I will say that I hope your case is not cracked on that boss due to wedging that banjo bolt in there. I do know that it's a straight fine thread - not tapered like a pipe thread.
Old Sep 12, 2023 | 07:40 PM
Alexis Garcia
Would you happen to know the thread size of the bolt sold on Diesel site, can’t seem to find the specifications on it? That would help my find the right thread repair kit I would need to fix the thread on the transmission
Old Sep 12, 2023 | 08:17 PM
RacinJasonWV's Avatar
RacinJasonWV
Can’t help you with thread sizes but wanted to mention a couple things for thought.
You want to make none of those aluminum shavings end up inside the trans. #1 rule of auto trans is cleanliness. Chips/debris are not welcome inside the unit.
Mark K (and myself) do not recommend the bypassing delete. The bypass is there for a reason. I’ll share a screenshot of Mark’s words on the topic.
Chris0611
Feb 16, 2023 09:35 AM
chucketn
Dec 29, 2022 07:06 PM
okie trucker
Aug 15, 2019 12:12 AM
hickory1991
May 21, 2012 08:03 PM
smitty 001
Dec 19, 2006 07:49 PM
