first blood
Old Dec 29, 2022 | 11:44 AM
chucketn's Avatar
chucketn
first blood
Well, my 1983 F-150 project truck has drawn first blood. Trying to install a no smog vac advance distributor. What a pain... I've dropped the hold down bolt, and naturally I can't find it... 351 Windsor, what size bolt will fit?
Old Dec 29, 2022 | 06:24 PM
Franklin2's Avatar
Franklin2
Didn't it take a 1/2 inch wrench? If it did, try a 5/16-18 bolt. That is a coarse thread bolt. I can't remember if it's coarse thread or fine thread. If it's fine thread, and it took a 1/2 wrench, then that would be a 5/16-24.
Old Dec 29, 2022 | 06:35 PM
chucketn's Avatar
chucketn
Yes, it did take a 1/2" wrench. I actually found the bolt and clamp under the truck, and measured it before trying again. I found the bolt was indeed a 5/16-18 thread. Then, I promptly dropped the bolt again. Still haven't found it. At least I have the clamp. Tomorrow I'll take the distributor back out and install a stud instead. Should make installing easier.
Old Dec 29, 2022 | 06:54 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Why are you removing the distributor to install the stud?
Old Dec 29, 2022 | 07:06 PM
chucketn's Avatar
chucketn
Because I'm 73 and not as dexterous as I used to be. I'll put a rag in the distributor hole to keep from dropping the stud down there. "If it was easy, everyone would do it..."
AbandonedBronco
17
Feb 5, 2020 03:28 PM
wileyinohio
18
Aug 12, 2016 05:40 PM
BloomingtonMike
May 1, 2007 01:41 AM
mikeyswood
Oct 14, 2005 07:39 AM
snipa
Nov 17, 2004 01:05 PM
